PRT-13784
PRT-13784
    SPARKFUNELECTRONICS
    电池
    SOLAR PANEL - 9W
PRT-13784 数据手册
Page 1 of 2   Solar Panel - 9W PRT-13 784 ROH S   images are CC BY-NC-SA 3.0 Description: Have a project that needs some good power? Do you like free power provided by our friend, Mr. Sun? Check out this high quality, high output, fully enclosed solar panel with a nice solid aluminum/plastic frame. The panel is capable of 9 watts in the open sun with a peak power output around 6V at 1500mA. The termination is equipped with a 3.5mm x 1.1mm barrel plug and 5.5mm x 2.1mm adapter on a 22cm (8in) cable making the panel able to mate directly with many of our development boards. Each panel also features monocrystalline high efficiency cells at 19% with a waterproof urethane coating with hard-board backing. With robust sealing for out door applications this solar panel is incredibly durable and reliable! Page 2 of 2 Dimensions: 220mm x 255mm x 5mm (8.7in x 10.1in x 0.2in) Includes: • 1x Solar Panel - 9W • 1x Barrel Plug Adapter - 3.5mm to 5.5mm Features: • • • • • • • • Monocrystalline cells - 19% efficient Open Circuit Voltage: 7.0V Peak Voltage: 6.0V Peak Current: 1500mA Peak Power: 9.0 Watts Four screws on back corners of panel allow multiple mounting options Waterproof Urethane Coating UV Resistant https://www.sparkfun.com/products/13784 4/13/2016
PRT-13784 价格&库存
很抱歉,暂时无法提供与“PRT-13784”相匹配的价格&库存,您可以联系我们找货
