PRT-14273
PRT-14273
    SPARKFUNELECTRONICS
    CASE RED/WHITE RASPBERRY PI ZERO
PRT-14273 数据手册
    Raspberry Pi Zero Case PRT-14273 Description: The Raspberry Pi Zero Case has been designed to fit both the Pi Zero and the Pi Zero W. These official cases consist of several parts and protect the Raspberry Pi Zero from things like rogue wires that might short it out while still allowing full access to the board. Simply snap the RPi into the bottom half of the enclosure, then snap on a desired top. No tools required! Each case has a standard base featuring a cut-out to allow access to the GPIO, and a choice of three lids: a standard lid, a GPIO lid (allowing access to the GPIO pins from above) and a camera lid (which, when used with the short camera cable supplied, allows the Raspberry Pi camera to be fitted neatly inside it). Additionally, each case includes a 4cm long CSI cable and four rubber feet. Note: This case does NOT include a Raspberry Pi or Camera Module. Includes:       1x Base 1x Standard Lid 1x GPIO Lid 1x Camera Lid 1x Short Camera Cable 4x Rubber Feet                                                      https://www.sparkfun.com/products/14273 7‐21‐17
PRT-14273 价格&库存
很抱歉,暂时无法提供与“PRT-14273”相匹配的价格&库存,您可以联系我们找货
