Qwiic Cable - Grove Adapter (150mm)
PRT-15109
With the SparkFun Qwiic Connect System expanding every day, we want to make sure it becomes
as accessible as possible but we understand there are other systems that can compliment it out
there. The Qwiic to Grove Adapter Cable allows interoperability between the SparkFun Qwiic
Connect System and the I2C based Grove boards from Seeed Studio. Now you can plug Seeed
Studio boards you may have onto the Qwiic bus or you can use this cable to introduce Qwiic
sensors, inputs, and outputs into your Grove system.
Note: The Grove system has a variety of different signal systems that use the same connector. This
cable only works with the I2C variety.
The SparkFun Qwiic connect system is an ecosystem of I2C sensors, actuators, shields and cables
that make prototyping faster and less prone to error. All Qwiic-enabled boards use a common 1mm
pitch, 4-pin JST connector. This reduces the amount of required PCB space, and polarized
connections mean you can’t hook it up wrong.
FEATURES
Length: 150mm
https://www.sparkfun.com/products/15109 12‐3‐18
很抱歉,暂时无法提供与“PRT-15109”相匹配的价格&库存,您可以联系我们找货
