PRT-21257
PRT-21257
    SPARKFUNELECTRONICS
    GNSS,GPS 圆顶 RF 天线 TNC 磁性
PRT-21257 数据手册
GNSS Magnetic Antenna Mount - 5/8" 11-TPI PRT-21257 This is a very handy magnetic mount for survey grade GNSS/GPS antennas. Sturdy, compact, and surprisingly strong, this is a quick way of mounting your antenna to metal roofs, parapets, and other ferrous materials. The rod is threaded 5/8" 11-TPI (threads per inch) found on high-end surveying antennas and equipment. Additionally, the mount is tall enough to prevent kinking or collision between the TNC connector, cable, and the roof surface. While the magnetic strength is very high, it is not intended for automotive applications as larger antennas may cause the mount to shear off at high speeds. https://www.sparkfun.com/products/21257 1-6-2023
PRT-21257 价格&库存
很抱歉,暂时无法提供与“PRT-21257”相匹配的价格&库存,您可以联系我们找货
PRT-21257
    库存:17
