SEN-17777
SEN-17777
    SPARKFUNELECTRONICS
    HC-SR04 超声波 传感器 Qwiic 平台评估扩展板
SEN-17777 数据手册
  Qwiic Ultrasonic Distance Sensor (HC-SR04) Hookup Guide Introduction The SparkFun Qwiic Ultrasonic Distance Sensor is great for providing non-contact distance readings from 2cm to 400cm. It improves on the classic HC-SR04 distance sensor by adding a pair of Qwiic connectors to it, so now you can communicate over I2C and daisy chain any other Qwiic product of your choosing. If you prefer to bypass the Qwiic connector and I2C you can also access the VCC, Trigger, Echo, and Ground pins broken out on the edge of the board. Please be aware that this ultrasonic sensor comes uncalibrated and you will need manipulate the raw output for your specific application. Let's have a look at this fun board! SparkFun Qwiic Ultrasonic Distance Sensor - HC-SR04  SEN-17777 Required Materials To follow along with this tutorial, you will need the following materials. You may not need everything though depending on what you have. Add it to your cart, read through the guide, and adjust the cart as necessary. Qwiic Ultrasonic Distance Sensor (HC-SR04) Wish List SparkFun Wish List SparkFun Qwiic Ultrasonic Distance Sensor - HC-SR04 SEN-17777 USB micro-B Cable - 6 Foot CAB-10215 SparkFun Qwiic OLED Display (0.91 128x32) USB 2.0 type A to micro USB 5-pin. This is in, a new, smaller connector for USB devices. Micro USB connectors are a… LCD-17153 (2) Qwiic Cable - 100mm PRT-14427 SparkFun RedBoard Qwiic DEV-15123 Suggested Reading If you aren't familiar with the Qwiic system, we recommend reading here for an overview. Qwiic Connect System We would also recommend taking a look at the following tutorials if you aren't familiar with them. How to Solder: Through-Hole Soldering I2C This tutorial covers everything you need to know about through-hole soldering. An introduction to I2C, one of the main embedded communications protocols in use today. Serial Terminal Basics This tutorial will show you how to communicate with your serial devices using a variety of terminal emulator applications. Hardware Overview Overall Features: Operating Voltage 3.3V Detecting Angle: 15 degrees Sensor range: 2cm to 400cm Accuracy: 3mm MCU on board: STM8L051 Default I2C Address: 0x00 Dimensions: 21.5 x 45.5mm Weight 9.2g STM8L051 MCU The 8-bit ultra-low power STM8 MCU Core provides increased processing power (up to 16 MIPS at 16 MHz) while maintaining the advantages of a CISC architecture with improved code density, a 24-bit linear addressing space and an optimized architecture for low power operations. It also features embedded data EEPROM and low power, low-voltage, single-supply program Flash memory. The device incorporates an extensive range of enhanced I/Os and peripherals, a 12-bit ADC, a real-time clock, two 16-bit timers, one 8-bit timer, as well as standard communication interfaces such as an SPI, an I2C interface, and one USART. For more information, refer to the datasheet. Qwiic Connectors Our Qwiic Ecosystem makes sensors pretty much plug and play. There are two Qwiic connectors on the side of the Qwiic Distance Sensor board to provide power and I2C connectivity simultaneously. Power Ideally, power will be supplied via the Qwiic connectors on either side of the board. Alternatively, power can be supplied through the pins along the bottom side of the board labeled 3V3 and GND . The input voltage range should be between 1.8-3.6V. Trigger and Echo Pins If you (for some crazy reason) don't want to utilize the Qwiic connectors, we've broken out the Trigger and Echo pins as PTH. We've included headers that can be soldered in place. I2C Jumpers The Qwiic Ultrasonic Distance Sensor has built-in 2.2k pull-up resistors on the SDA and SCL lines. These are needed for normal I2C communication. The I2C jumper has two small traces connecting the pull-ups to 3.3V. For general use you can leave this jumper unmodified. If you have many (over 7) devices on the I2C bus, each with their own pull up resistors, then you may want to cut the I2C jumpers to disconnect the 2.2k resistors on each Qwiic board. Board Dimensions Units below are in mm. Hardware Hookup Using the Qwiic system, assembling the hardware is simple. Connect the RedBoard to one of the Ultrasonic Distance Sensor Qwiic ports and the Qwiic OLED Display on the other Qwiic port using your Qwiic cables. Then connect the RedBoard to your computer via the MicroUSB cable and voila! You're ready to rock! Software Setup and Programming Note: Make sure you are using the latest stable version of the Arduino IDE on your desktop. If this is your first time using Arduino IDE, library, or board add-on, please review the following tutorials. Installing the Arduino IDE Installing an Arduino Library Installing Board Definitions in the Arduino IDE Our friends over at Zio have provided an example to get you started with this Ultrasonic Distance Sensor. In order to do so, you'll need to install a few libraries first. To display the sensor readings on the connected Qwiic OLED, we will use three Adafruit libraries: Adafruit BusIO GitHub Adafruit GFX GitHub Adafruit SSD1306 GitHub Adafruit BusIO Library You can install this library to automatically in the Arduino IDE's Library Manager by searching for "Adafruit BusIO". Or you can manually download it from the GitHub repository. DOWNLOAD THE ADAFRUIT BUSIO LIBRARY (ZIP) Adafruit GFX Library You can install this library to automatically in the Arduino IDE's Library Manager by searching for "Adafruit GFX". Or you can manually download it from the GitHub repository. DOWNLOAD THE ADAFRUIT GFX LIBRARY (ZIP) Adafruit SSD1306 Library You can install this library to automatically in the Arduino IDE's Library Manager by searching for "Adafruit SSD1306 Library". Or you can manually download it from the GitHub repository. DOWNLOAD THE ADAFRUIT SSD1306 LIBRARY (ZIP)  Pro tip: Trying to do a search for the Adafruit libraries and not finding them? Make sure you have the Adafruit json link in your Preferences. After your SparkFun json link, of course. Example 1 This example lives in the GitHub Repo in the Arduino folder. Feel free to download the code, alternatively you can copy the code below into a blank Arduino sketch. Select your board (for this example we'd select "SparkFun RedBoard") and the port your board has enumerated on. Go ahead and upload your code. #include #include #include #define SLAVE_BROADCAST_ADDR 0x00 //default address #define SLAVE_ADDR 0x00 //SLAVE_ADDR 0xA0-0xAF uint8_t distance_H = 0; uint8_t distance_L = 0; uint16_t distance = 0; #define SCREEN_WIDTH 128 // OLED display width, in pixels #define SCREEN_HEIGHT 32 // OLED display height, in pixels // Declaration for an SSD1306 display connected to I2C (SDA, SCL pins) #define OLED_RESET 4 // Reset pin # (or -1 if sharing Arduino reset pin) Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET); void setup() { Wire.begin(); // join i2c bus (address optional for master) Serial.begin(9600); // start serial for output display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // initialize with the I2C addr 0x3C (for the 128x 32) Serial.println("IIC testing......"); display.clearDisplay(); // Wire.beginTransmission(SLAVE_BROADCAST_ADDR); // transmit to device SLAVE_BROADCAST_ADDR // Wire.write(SLAVE_ADDR); // Change the SLAVE_ADDR // Wire.endTransmission(); // stop transmitting } void loop() { Wire.beginTransmission(SLAVE_ADDR); // transmit to device #8 Wire.write(1); // measure command: 0x01 Wire.endTransmission(); // stop transmitting Wire.requestFrom(SLAVE_ADDR, 2); // request 6 bytes from slave device #8 while (Wire.available()) { // slave may send less than requested distance_H = Wire.read(); // receive a byte as character distance_L = Wire.read(); distance = (uint16_t)distance_H
SEN-17777 价格&库存
很抱歉,暂时无法提供与“SEN-17777”相匹配的价格&库存,您可以联系我们找货
