ROB-10455
ROB-10455
    SPARKFUNELECTRONICS
    LIQUID PUMP - 350GPH 12V
ROB-10455 数据手册
      Liquid Pump - 350GPH (12v) ROB-10455 Do you have some liquids that you need to move? This fluid pump will move 350 gallons per hour! The SEAFLO mini water pump has a heavy duty 12V, 1.5Amp motor and a tough thermoplastic body. It’s totally submersible and water-cooled (but it won’t burn out if run dry). Use this pump to make a fountain or waterfall, even water your plants! The ¾" connection will accept a 19mm ID hose. It comes pre-terminated with heavy gauge unterminated 3ft long wire leads.      12V operation 350 GPH 1.5A motor ¾" barbed outlet 3ft long wire leads        https://www.sparkfun.com/products/10455 9‐18‐17
ROB-10455 价格&库存
很抱歉,暂时无法提供与“ROB-10455”相匹配的价格&库存,您可以联系我们找货
