SparkFun Motor Driver - Dual TB6612FNG
(with Headers)
ROB-14450 RoHS
DESCRIPTION
The TB6612FNG Motor Driver can control up to two DC motors at a constant current of 1.2A (3.2A
peak). Two input signals (IN1 and IN2) can be used to control the motor in one of four function
modes: CW, CCW, short-brake and stop. The two motor outputs (A and B) can be separately
controlled, and the speed of each motor is controlled via a PWM input signal with a frequency up to
100kHz. The STBY pin should be pulled high to take the motor out of standby mode. Due to popular
demand, this version of the SparkFun Motor Driver includes pre-soldered male headers for ease of
use. With the headers already soldered on, you can jump right in to using this little board without any
assembly!
Logic supply voltage (VCC) can be in the range of 2.7–5.5VDC, while the motor supply (VM) is
limited to a maximum voltage of 15VDC. The output current is rated up to 1.2A per channel (or up to
3.2A for a short, single pulse).
The board comes with all components installed as shown. Decoupling capacitors are included on
both supply lines. All pins of the TB6612FNG are broken out to two 0.1" pitch headers; the pins are
arranged such that input pins are on one side and output pins are on the other.
FEATURES
Power supply voltage: VM = 15V max, VCC = 2.7–5.5V
Output current: Iout = 1.2A (average) / 3.2A (peak)
Standby control to save power
CW/CCW/short-brake/stop motor control modes
Built-in thermal shutdown circuit and low-voltage detecting circuit
All pins of the TB6612FNG broken out to 0.1" spaced pins
Filtering capacitors on both supply lines
Pre-soldered headers
https://www.sparkfun.com/products/14450 11‐13‐17
很抱歉,暂时无法提供与“ROB-14450”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+137.543401+17.74350
