ROB-14538
ROB-14538
    SPARKFUNELECTRONICS
    DRV2605L 电机控制器/驱动器,触觉/振动 电源管理 评估板
ROB-14538 数据手册
    SparkFun Haptic Motor Driver - DRV2605L ROB-14538 Ready to add some good vibes to your project? Look no further than the SparkFun Haptic Motor Driver. This board breaks out Texas Instruments' DRV2605L Haptic Motor Driver, which adds meaningful feedback from your devices using the breakout and an Arduino-compatible device. The DRV2605L is capable of driving two different types of motors, ERM and LRA. It is important to know, however, that the default firmware for the DRV2605L is set for use with ERM-type motors. We have created an Arduino library that makes the DRV2605L easy to use with six different ERM effects and one LRA effect. The SparkFun Haptic Motor Driver breakout board features six pins to provide power to the sensor and I2C bus. Additionally, a microcontroller that supports I2C is required to communicate with the DRV2605L and relay the data to the user by means of vibration. FEATURES       Flexible Haptic and Vibration Driver for both ERM and LRA type motors I2C-Controlled Digital Playback Engine Audio to Vibe PWM input with 0–100% Duty-Cycle Control Range Hardware Trigger Input Built-in Waveform Sequencer and Trigger                                                        https://www.sparkfun.com/products/14538 5‐15‐18
ROB-14538 价格&库存
很抱歉,暂时无法提供与“ROB-14538”相匹配的价格&库存,您可以联系我们找货
