ROB-21245
ROB-21245
    SPARKFUNELECTRONICS
    直流电机 齿轮电机 140 RPM 4.5VDC
ROB-21245 数据手册
Hobby Gearmotor - 140 RPM, Male Connectors (Single) ROB-21245 RoHS This is a hobby gearmotor from DAGU. These gearmotors are the same ones recommended for use in the Shadow Chassis and offer a cheap and easy-to-use setup to get your wheels turning. Each Hobby Gearmotor also possess a 9mm long output on a straight axis. These gearmotors require a voltage of 4.5V with a no load current of 190mA while possessing a gearbox ratio of 48:1 and a wheel speed of 140 RPM unloaded. https://www.sparkfun.com/products/21245 12-1-2022
ROB-21245 价格&库存
很抱歉,暂时无法提供与“ROB-21245”相匹配的价格&库存,您可以联系我们找货
