GPS-19984
GPS-19984
    SPARKFUNELECTRONICS
    高精度地理定位,测绘 RTK Facet
GPS-19984 数据手册
YOURACNT REGIST LOGIN  SparkFun RTK Facet Hookup Guide Introduction The RTK Facet from SparkFun is our most advanced GNSS receiver to date. It's your one stop shop for high precision geolocation and surveying needs. For basic users, it’s incredibly easy to get up and running and for advanced users, the RTK Facet is a flexible and powerful tool. SparkFun RTK Facet  GPS-19984 With just a few minutes of setup, the RTK Facet is one of the fastest ways to take centimeter grade measurements. Surveying with a monopod and SW Maps An RTK Fix with 14mm accuracy in SW Maps By connecting your phone to the RTK Facet over Bluetooth, your phone can act as the radio link to provide correction data as well as receive the NMEA output from the device. It’s how $10,000 surveying devices have been operating for the past decade - we just made it easier, smaller, and a lot more economical. Required Materials The RTK Facet has all you need built into one small unit. In addition, the RTK Facet Kit includes everything you might need as well. The only thing you need to add is your own tablet or cell phone (currently Android is supported; iOS support planned). Depending on your setup you may want to use your phone for RTCM correction data. If a source is not available online, you will need a 2nd RTK Facet setup in base mode and a radio link connecting the Base to the Rover. We'll go into details but we designed RTK Facet to work with these 100mW 915MHz telemetry radios out of the box. SiK Telemetry Radio V3 - 915MHz, 100mW  WRL-19032 To charge the RTK Facet you will need a USB C cable and a power supply. These are included with the kit but any USB C port should charge the Facet at a maximum rate of 1A per hour. USB 2.0 Type-C Cable - 1 Meter Reversible USB A to C Cable - 0.8m  CAB-16905  CAB-15425 USB Wall Charger - 5V, 2A USB-C Wall Adapter - 5.1V, 3A (Black)  TOL-16893  TOL-16272 Suggested Reading GNSS RTK is an incredible feat of engineering that has been made easy to use by powerful GNSS receivers such as the ZED-F9P by u-blox (the receiver inside RTK Facet). The process of setting up an RTK system will be covered in this tutorial but if you want to know more about RTK here are some good tutorials to brush up on: What is GPS RTK? Getting Started with U-Center for u-blox Learn about the latest generation of GPS and GNSS receivers to get 14mm positional accuracy! Learn the tips and tricks to use the u-blox software tool to configure your GPS receiver. GPS-RTK2 Hookup Guide Setting up a Rover Base RTK System Get precision down to the diameter of a dime with the new ZED-F9P from u-blox. Getting GNSS RTCM correction data from a base to a rover is easy with a serial telemetry radio! We'll show you how to get your high precision RTK GNSS system setup and running. How to Build a DIY GNSS Reference Station Learn how to affix a GNSS antenna, use PPP to get its ECEF coordinates and then broadcast your own RTCM data over the internet and cellular using NTRIP to increase rover reception to 10km! Hardware Overview The RTK Facet is a fully enclosed, preprogrammed device. There are very few things to worry about or configure but we will cover the basics. Power/Setup Button The RTK Facet has one button used for both Power and Setup for in-field configuration changes. Pressing and holding the Power button will cause it to power on or off. Short pressing the button will cause the RTK Facet to change modes. This device can be used in four modes: GNSS Positioning (~30cm accuracy) - also known as 'Rover' GNSS Positioning with RTK (1.4cm accuracy) - also known as 'Rover with RTK Fix' GNSS Base Station GNSS Base Station NTRIP Server At Power On the device will enter Rover or Base mode; whichever state the device was in at the last power down. When the POWER/SETUP button is pressed momentarily, a menu is presented to change the RTK Facet to Rover or Base mode. The display will indicate the change with a small car or flag icon. In Rover mode the RTK Facet will receive L1 and L2 GNSS signals from the four constellations (GPS, GLONASS, Galileo, and BeiDou) and calculate the position based on these signals. Similar to a standard grade GPS receiver, the RTK Facet will output industry standard NMEA sentences at 4Hz and broadcast them over any paired Bluetooth device. The end user will need to parse the NMEA sentences using commonly available mobile apps, GIS products, or embedded devices (there are many open source libraries). Unlike standard grade GPS receivers that have 2500m accuracy, the accuracy in this mode is approximately 300mm horizontal positional accuracy with a good grade L1/L2 antenna. When the device is in Rover mode and RTCM correction data is sent over Bluetooth or into the radio port, the device will automatically enter Positioning with RTK mode. In this mode RTK Facet will receive L1/L2 signals from the antenna and correction data from a base station. The receiver will quickly (within a second) obtain RTK float, then fix. The NMEA sentences will have increased accuracy of 14mm horizontal and 10mm vertical accuracy. The RTCM correction data is most easily obtained over the internet using a free app on your phone (see SW Maps or Lefebure NTRIP) and sent over Bluetooth to the RTK Facet but RTCM can also be delivered over an external cellular or radio link to a 2nd RTK Facet setup as a base station. In Base mode the device will enter Base Station mode. This is used when the device is mounted to a fixed position (like a tripod or roof). The RTK Facet will initiate a survey. After 60 to 120 seconds the survey will complete and the RTK Facet will begin transmitting RTCM correction data out the radio port. A base is often used in conjunction with a second RTK Facet (or RTK Surveyor) unit set to 'Rover' to obtain the 14mm accuracy. Said differently, the Base sits still and sends correction data to the Rover so that the Rover can output a really accurate position. You’ll create an RTK system without any other setup. Power RTK Facet startup display with firmware version number The Power button turns on and off the unit. Press and hold the power button until the display illuminates. Press and hold the power button at any time to turn the unit off. RTK Facet showing the battery level The RTK Facet has a large, built-in 6000mAh lithium polymer battery that will enable over 25 hours of field use between charging. If more time is needed a common USB power bank can be attached boosting the field time to any amount needed. Charge LED The Charge LED is located on the front face. It will illuminate any time there is an external power source and will turn off when the internal battery is charged. With the unit fully powered down, charging takes approximately 6 hours from a 1A wall supply or 12 hours from a standard USB port. The RTK Facet can run while being charged but it increases the charge time. Using an external USB battery bank to run the device for extended periods or running the device on a permanent wall power source is supported. Connectors The SparkFun RTK Facet connectors shown with the dust cover removed There are a variety of connectors protected by a dust flap. USB: This USB C connector is used for three purposes: Charging the device Configuring the RTK Facet, and reprogramming the ESP32 Directly configuring and inspecting the ZED-F9P GNSS receiver There is a USB hub built into the RTK Facet. When you attach the device to your computer it will enumerate as two COM ports. In the image above, the USB Serial Device is the ZED-F9P and the USB-SERIAL CH340 is the ESP32. Don't See 'USB-Serial CH340'? If you've never connected a CH340 device to your computer before, you may need to install drivers for the USB-to-serial converter. Check out our section on "How to Install CH340 Drivers" for help with the installation. Don't See 'USB Serial Device'? The first time a u-blox module is connected to a computer you may need to adjust the COM driver. Check out our section on "How to Install u-blox Drivers" for help with the installation. Configuring the RTK Facet can be done over the USB-Serial CH340 COM port via serial text menu. Various debug messages are printed to this port at 115200bps and a serial menu can be opened to configure advanced settings. Configuring the ZED-F9P can be configured over the USB Serial Device port using u-center. It’s not necessary in normal operation but is handy for tailoring the receiver to specific applications. As an added perk, the ZED-F9P can be detected automatically by some mobile phones and tablets. If desired, the receiver can be directly connected to a compatible phone or tablet removing the need for a Bluetooth connection. Radio: This port is used when an external cellular or radio link is needed. This port is not used if you transfer RTCM from your phone to the RTK Facet over Bluetooth. This 4-pin JST connector can be used to allow RTCM correction data to flow into the device when it is acting as a rover or out of the device when it is acting as a base. The connector is a 4-pin locking 1.25mm JST SMD connector (part#: SM04B-GHS-TB, mating connector part#: GHR-04V-S). The RTK Facet comes with a cable to interface to this connector but additional cables can be purchased. You will most likely connect this port to one of our Serial Telemetry Radios if you don’t have access to a correction source on the internet. The pinout is 3.5-5.5V / TX / RX / GND from left to right as pictured. 3.5V to 5.5V is provided by this connector to power a radio with a voltage that depends on the power source. If USB is connected to the RTK Facet then voltage on this port will be 5V (+/-10%). If running off of the internal battery then voltage on this port will vary with the battery voltage (3.5V to 4.2V depending on the state of charge). This port is capable of sourcing up to 600mA and is protected by a PTC (resettable fuse). This port should not be connected to a power source. Data: This port is used when an external system is connected such as a rover, car, timing equipment, camera triggers, etc. This port is not used if you transfer NMEA positional data to your phone from the RTK Facet over Bluetooth. This 4-pin JST connector is used to output and input a variety of data to the RTK Facet. The connector is a 4-pin locking 1.25mm JST SMD connector (part#: SM04B-GHS-TB, mating connector part#: GHR-04V-S). The RTK Facet comes with a cable to interface to this connector but additional cables can be purchased. Internally the Data connector is connected to a digital mux allowing one of four software selectable setups: NMEA - The TX pin outputs any enabled messages (NMEA, UBX, and RTCM) at a default of 460,800bps (configurable 9600 to 921600bps). The RX pin can receive RTCM for RTK and can also receive UBX configuration commands if desired. PPS/Trigger - The TX pin outputs the pulse-per-second signal that is accurate to 30ns RMS. The RX pin is connected to the EXTINT pin on the ZED-F9P allowing for events to be measured with incredibly accurate nano-second resolution. Useful for things like audio triangulation. See the Timemark section of the ZED-F9P integration for more information. I2C - The TX pin operates as SCL, RX pin as SDA on the I2C bus. This allows additional sensors to be connected to the I2C bus. GPIO - The TX pin operates as a DAC capable GPIO on the ESP32. The RX pin operates as a ADC capable input on the ESP32. This is useful for custom applications. Most applications do not need to utilize this port and will send the NMEA position data over Bluetooth. This port can be useful for sending position data to an embedded microcontroller or single board computer. The pinout is 3.3V / TX / RX / GND. 3.3V from left to right as pictured, which is provided by this connector to power a remote device if needed. While the port is capable of sourcing up to 600mA, we do not recommend more than 300mA. This port should not be connected to a power source. microSD: This slot accepts standard microSD cards up to 32GB formatted for FAT16 or FAT32. Logging any of 67 messages at up to 4Hz is supported for all constellations. The following 67 messages are supported for logging: • NMEA-GSA • NMEA-RMC • NMEA-ZDA • NAV-EOE • NAV-HPPOSLLH • NAV-POSECEF • NAV-RELPOSNED • NAV-STATUS • NAV-TIMEGAL • NAV-TIMELS • NAV-VELNED • RXM-RLM • MON-COMMS • MON-HW • MON-RF • MON-TXBUF • TIM-VRFY • RTCM3x-1077 • RTCM3x-1094 • RTCM3x-1127 • RTCM3x-4072-1 Qwiic: • NMEA-GST • NMEA-VLW • NAV-CLOCK • NAV-GEOFENCE • NAV-ODO • NAV-POSLLH • NAV-SAT • NAV-SVIN • NAV-TIMEGLO • NAV-TIMEUTC • RXM-MEASX • RXM-RTCM • MON-HW2 • MON-IO • MON-RXBUF • TIM-TM2 • RTCM3x-1005 • RTCM3x-1084 • RTCM3x-1097 • RTCM3x-1230 • NMEA-GSV • NMEA-VTG • NAV-DOP • NAV-HPPOSECEF • NAV-ORB • NAV-PVT • NAV-SIG • NAV-TIMEBDS • NAV-TIMEGPS • NAV-VELECEF • RXM-RAWX • RXM-SFRBX • MON-HW3 • MON-MSGPP • MON-RXR • TIM-TP • RTCM3x-1074 • RTCM3x-1087 • RTCM3x-1124 • RTCM3x-4072-0 This 4-pin Qwiic connector exposes the I2C bus of the ESP32 WROOM module. Currently, there is no firmware support for adding I2C devices to the RTK Facet but support may be added in the future. Antenna: It's built in! Housed under the dome of the RTK Facet is a surveyor grade L1/L2 antenna. It is the same element found within our GNSS Multi-Band L1/L2 Surveying Antenna. Its datasheet is available here. SparkFun RTK Facet Antenna Reference Points The built in antenna has an ARP of 61.4mm from the base to the measuring point of the L1 antenna and an ARP of 57.4mm to the measuring point of the L2 antenna. Power RTK Facet Display showing three battery bars The RTK Facet has a built in 6000mAh battery and consumes approximately 240mA worst case with Bluetooth connection active and GNSS fully tracking. This will allow for around 25 hours of use in the field. If more time is needed in the field a standard USB power bank can be attached. If a 10,000mAh bank is attached one can estimate 56 hours of run time assuming 25% is lost to efficiencies of the power bank and charge circuit within RTK Facet. The RTK Facet can be charged from any USB port or adapter. The charge circuit is rated for 1000mA so USB 2.0 ports will charge at 500mA and USB 3.0+ ports will charge at 1A. To quickly view the state of charge, turn on the unit. The battery icon will indicate the following: 3 bars: >75% capacity remain 2 bars: >50% capacity remain 1 bar: >25% capacity remain 0 bars:
GPS-19984 价格&库存
很抱歉,暂时无法提供与“GPS-19984”相匹配的价格&库存,您可以联系我们找货
