SEN-10612
SEN-10612
    SPARKFUNELECTRONICS
    TRI-AXIS GYRO BREAKOUT - L3G4200
SEN-10612 数据手册
 Export Restrictions This product has some level of export control/restriction, so may be delayed by 2-3 business days when shipping outside the United States. Contact us with questions, or we will contact you after you place your order. SparkFun Tri-Axis Gyro Breakout - L3G4200D S EN -10 612 RO HS   images are CC BY-NC-SA 3.0 Description: This is a breakout board for the L3G4200D low-power three-axis angular rate sensor. The L3G4200D is a MEMS motion sensor and has a full scale of ±250/±500/±2000 dps and is capable of measuring rates with a user-selectable bandwidth. These work great in gaming and virtual reality input devices, GPS navigation systems and robotics. Not sure which gyro is right for you? Our Accelerometer and Gyro Buying Guide might help! Features: • • • • • • • • • Three selectable full scales (250/500/2000 dps) I2C/SPI digital output interface 16 bit-rate value data output 8-bit temperature data output Wide supply voltage: 2.4 V to 3.6 V Low voltage-compatible IOs (1.8 V) Embedded power-down and sleep mode Embedded temperature sensor High shock survivability https://www.sparkfun.com/products/10612 10/8/2015
SEN-10612 价格&库存
很抱歉,暂时无法提供与“SEN-10612”相匹配的价格&库存,您可以联系我们找货
