SparkFun RFID Reader Breakout
SEN-13030 RoHS
Description: This is a simple breakout board for our RFID readers. The SparkFun RFID Reader
Breakout converts the 2mm pins to bread board friendly 0.1" headers. With this ability the ID-3LA,
ID-12LA, and the ID-20LA you can solder the reader directly to the breakout board or use the 2mm
sockets.
This breakout board’s edges actually fit flush within the under side the ID-12LA. The board also
works with the ID-20LA, but is smaller than the edges. As stated before each pin of the RFID reader
has been broken out including: VCC, READ, D0, D1, FORM, TIR, CP, both ANTs, RES, and GND.
We’ve even added four half-mounting holes to the board to easily secure your project!
Note: If you are concerned about soldering this board directly to the RFID reader, you can use 2mm
sockets instead. This is due to the RFID being sensitive to heat and should be handled with care or if
you would like to switch the readers out as you please.
https://www.sparkfun.com/products/13030 6‐20‐17
很抱歉,暂时无法提供与“SEN-13030”相匹配的价格&库存,您可以联系我们找货
