SEN-13332
SEN-13332
    SPARKFUNELECTRONICS
    LOAD CELL - 200KG DISC TAS606
SEN-13332 数据手册
    Load Cell - 200kg, Disc (TAS606) SEN-13332 RoHS This disc load cell (sometimes called a strain gauge) can translate up to a whopping 200kg of pressure (force) into an electrical signal. Each load cell is able to measure the electrical resistance that changes in response to, and proportional of, the strain (e.g. pressure or force) applied to the disc. With this gauge you will be able to tell just how heavy an object is, if an object’s weight changes over time, or if you simply need to sense the presence of an object by measuring strain or load applied to a surface. Disc load cells are a bit easier to mount than bar-style load cells, making them more straightforward to implement into a design. Each load cell is made from an steel-alloy and is capable of reading a capacity of 200kg. These load cells have four strain gauges that are hooked up in a wheatstone bridge formation. The color code on the wiring is as follows: red = E+, green = O+, black = E-, and white = O-. Additionally, these load cells offer an IP66 protection rating. 20mm x 11mm, 2000mm Wire        https://www.sparkfun.com/products/13332 9‐18‐17
SEN-13332
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种高速光耦器件,具有高隔离电压和快速响应时间。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚输出,4脚接地,5脚Vcc,6脚输出。
4. 参数特性:工作温度范围为-40℃至+85℃,隔离电压为5000Vrms,响应时间为1us。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,具有抗干扰能力强、响应速度快等特点。
6. 应用信息:广泛应用于通信、工业控制、医疗设备等领域。
7. 封装信息:采用DIP-6封装形式。
SEN-13332 价格&库存
很抱歉,暂时无法提供与“SEN-13332”相匹配的价格&库存,您可以联系我们找货
