SEN-14351
SEN-14351
    SPARKFUNELECTRONICS
    AS7263 光 传感器 Qwiic 平台评估扩展板
SEN-14351 数据手册
    SparkFun Spectral Sensor Breakout - AS7263 NIR (Qwiic) SEN-14351 RoHS Open Source Hardware The SparkFun AS7263 Near Infrared (NIR) Spectral Sensor Breakout brings spectroscopy to the palm of your hand, making it easier than ever to measure and characterize how different materials absorb and reflect different wavelengths of light. The AS7263 Breakout is unique in its ability to communicate by both an I2C interface and serial interface using AT commands. Hookup is easy, thanks to the Qwiic connectors attached to the board — simply plug one end of the Qwiic cable into the breakout and the other into one of the Qwiic shields, then stack the board on a development board. You’ll be ready to upload a sketch to start taking spectroscopy measurements in no time. The AS7263 spectrometer detects wavelengths in the visible range at 610, 680, 730, 760, 810 and 860nm of light, each with 20nm of full-width half-max detection. The board also has multiple ways for you to illuminate objects that you will try to measure for a more accurate spectroscopy reading. There is an onboard LED that has been picked out specifically for this task, as well as two pins to solder your own LED into. The SparkFun Qwiic Connect System is an ecosystem of I2C sensors, actuators, shields and cables that make prototyping faster and less prone to error. All Qwiic-enabled boards use a common 1mm pitch, 4-pin JST connector. This reduces the amount of required PCB space, and polarized connections mean you can’t hook it up wrong. FEATURES       6 near-IR channels: 610nm, 680nm, 730nm, 760nm, 810nm and 860nm, each with 20nm FWHM NIR filter set realized by silicon interference filters 16-bit ADC with digital access Programmable LED drivers 2.7V to 3.6V with I2C interface 2x Qwiic connectors Notice. This product requires other products in order to function properly. See essential products. Essentials SparkFun OpenPIR SEN-13968 Qwiic Cable ‐ 100mm PRT-14427 SparkFun Qwiic Shield for Arduino DEV-14352 SparkFun RedBoard ‐ Programmed with Arduino DEV-13975                                                 https://www.sparkfun.com/products/14351 10‐23‐17
SEN-14351 价格&库存
很抱歉,暂时无法提供与“SEN-14351”相匹配的价格&库存,您可以联系我们找货
