SEN-14520
SEN-14520
    SPARKFUNELECTRONICS
    AT42QT1011 - 触摸,电容式 评估板 - 传感器
SEN-14520 数据手册
        SparkFun Capacitive Touch Breakout ‐ AT42QT1011 SEN-14520 If you need to add user input without using a button, then a capacitive touch interface might be the answer. The AT42QT1011 SparkFun Capacitive Touch Breakout offers a single, momentary capacitive touch button with easy-to-use digital I/O pins. The AT42QT1011 is a dedicated, single-button capacitive sense chip. The chip handles monitoring a conductive area for touch. As long as a touch (e.g., from a finger) is detected, the AT42QT1011 keeps the output line high. Otherwise, the line is kept low. You just need to provide a power source (1.8V–5V) and ground for the AT42QT1011 to work. Additionally, a PAD pin is available if you would like to create your own external electrode. Unlike its sibling, the AT42QT1011 does not have an internal time-out, meaning that if you hold your finger to the breakout’s pad for any length of time, it will stay on. The difference between the AT42QT1010 and the AT42QT1011 is small but may be a game changer depending on your project’s uses.        https://www.sparkfun.com/products/14520 1‐29‐18
SEN-14520 价格&库存
很抱歉,暂时无法提供与“SEN-14520”相匹配的价格&库存,您可以联系我们找货
SEN-14520
    • 1+87.60960
    • 200+34.95960
    • 500+33.79320
    • 1000+33.21000
