SEN-14607
SEN-14607
    SPARKFUNELECTRONICS
    AMG8833 温度(IR) 传感器 Qwiic 平台评估扩展板
SEN-14607 数据手册
        SparkFun Grid-EYE Infrared Array Breakout - AMG8833 (Qwiic) SEN-146 0 7 R O H S O p e n S o u rc e H a r d w a r e Get ready to be able to see like the Predator! The SparkFun Grid-EYE Infrared Array Breakout board is an 8x8 thermopile array, meaning you have a square array of 64 pixels capable of independent temperature detection. It’s like having a thermal camera, just in a lower resolution. To make it even easier to to get your low-resolution infrared image, all communication is enacted exclusively via I2C, utilizing our handy Qwiic system. However, we still have broken out 0.1"-spaced pins in case you prefer to use a breadboard. The on-board AMG8833 Grid-EYE possesses an accuracy rate of ±2.5°C (±4.5°F) with a temperature range of 0°C to 80°C (32°F to 176°F). Additionally, this IR “camera” board can detect human body heat at about 7 meters or less (that’s about 23 feet), and has a frame rate of 10 frames a second to one frame a second. It is important to point out that while this version of the Grid-EYE is the high performance type with a high gain, it is only 3.3V tolerant. IE: Don’t try to operate it at 5V (you won’t have a very good time). The SparkFun Qwiic connect system is an ecosystem of I2C sensors, actuators, shields and cables that make prototyping faster and less prone to error. All Qwiic-enabled boards use a common 1mm pitch, 4-pin JST connector. This reduces the amount of required PCB space, and polarized connections mean you can’t hook it up wrong. FEATU RES          Operating Voltage(Startup): 1.6V - 3.6V Operating Voltage(Timekeeping): 1.5V - 3.6V Current Consumption: 4.5 mA 8x8 Thermopile Array Temperature Range: 0°C to 80°C (32°F to 176°F) Accuracy Rate: ±2.5°C (±4.5°F) Human Detection Distance: 7m or less (22.966ft) I2C Address: 0x69 (open jumper, default) or 0x68 (closed jumper) 2x Qwiic Connection Ports        https://www.sparkfun.com/products/14607 5‐8‐18
SEN-14607 价格&库存
很抱歉,暂时无法提供与“SEN-14607”相匹配的价格&库存,您可以联系我们找货
