SEN-14835
SEN-14835
    SPARKFUNELECTRONICS
    RASPBERRYHOME EARTHQUAKE MONITOR
SEN-14835 数据手册
      Raspberry Shake - Home Earthquake Monitor (RS1D) SEN-14835 This shake brings an easy-to-use earthquake monitor to the yard! Developed and made on a literal volcano, the Raspberry Shake is a highly accurate seismograph you can use in your home, office, and classroom. This Raspberry Pi accessory uses a single, vertical geophone as its sensor – a very sensitive yet rugged Earth motion microphone widely used in the oil and gas industry, to detect seismic vibration. The Raspberry Shake was originally designed with citizen scientists and educational facilities in mind, but can easily be used by other hobbyists, makers, and enthusiasts, as well! Included with this kit is everything you need to equip your Raspberry Pi Zero, Pi Zero W, 3 Model B, 3 Model B+, 2 Model B, Model B and Model B+ with everything it needs to detect and measure earthquakes and seismic activities like fracking, explosions, eruptions, avalanches, landslides, and more. All you need supply is the Raspberry Pi itself. Note: The Raspberry Shake Home Earthquake Monitor only includes the parts found in the Includes Tab. This kit will require some assembly and does NOTinclude a Raspberry Pi or power source. These items will need to be purchased separately. INCLUDES     1x Raspberry Shake Circuit Board 1x Vertical Earth motion Monitoring Sensor (“Geophone”, 4.5Hz) with Cables 1x Enclosure 1x 8GB Micro SD Card (pre-programmed) https://www.sparkfun.com/products/14835 10-4-18
SEN-14835 价格&库存
很抱歉,暂时无法提供与“SEN-14835”相匹配的价格&库存,您可以联系我们找货
