SEN-14843
SEN-14843
    SPARKFUNELECTRONICS
    ARRAY BREAKOUT 110 FOV MLX90640
SEN-14843 数据手册
SparkFun IR Array Breakout - 110 Degree FOV, MLX90640 (Qwiic) SEN-14843 It’s time to say hip hip array for this IR Breakout! The MLX90640 SparkFun IR Array Breakout is equipped with a 32x24 array of thermopile sensors creating, in essence, a low resolution thermal imaging camera. With this breakout you can detect surface temperatures from many feet away with an accuracy of ±1.5°C (best case). To make it even easier to get your low-resolution infrared image, all communication is enacted exclusively via I2C, utilizing our handy Qwiic system. However, we still have broken out 0.1"-spaced pins in case you prefer to use a breadboard. This specific IR Array Breakout features a 110°x75° field of view with a temperature measurement range of -40°C-300°C. The MLX90640 IR Array has pull up resistors attached to the I2C bus; both can be removed by cutting the traces on the corresponding jumpers on the back of the board. Please be aware that the MLX90640 requires complex calculations by the host platform so a regular Arduino Uno (or equivalent) doesn’t have enough RAM or flash to complete the complex computations required to turn the raw pixel data into temperature data. You will need a microcontroller with 20,000 bytes or more of RAM. To achieve this, we recommend a Teensy 3.1 or above. The SparkFun Qwiic connect system is an ecosystem of I2C sensors, actuators, shields and cables that make prototyping faster and less prone to error. All Qwiic-enabled boards use a common 1mm pitch, 4-pin JST connector. This reduces the amount of required PCB space, and polarized connections mean you can’t hook it up wrong. FEATURES • • • • • • • • Operating Voltage: 3V-3.6V Current Consumption: ~18mA Field of View: 110°x75° Measurement Range: -40°C-300°C Resolution: ±1.5°C Refresh Rate: 0.5Hz-64Hz I2C Address: 0x33 2x Qwiic Connection Ports https://www.sparkfun.com/products/14843 10-2-18
SEN-14843
物料型号:SEN-14843
器件简介:MLX90640 SparkFun IR Array Breakout是一个低分辨率热成像相机,配备32x24的热电堆传感器阵列,可以远程检测表面温度。
引脚分配:SCL、SDA为I2C通信引脚,3.3V为电源引脚,GND为地线。
参数特性: - 操作电压:3V-3.6V - 电流消耗:约18mA - 视场:110°x75° - 测量范围:-40°C至300°C - 分辨率:±1.5°C - 刷新率:0.5Hz至64Hz - I2C地址:0x33
功能详解:该Breakout使用I2C通信,通过Qwiic系统简化连接。它需要一个至少有20,000字节RAM的微控制器来处理原始像素数据转换为温度数据的复杂计算。
应用信息:适合用于需要远程温度检测的各种应用场景。
封装信息:Qwiic连接系统,使用1mm间距,4针JST连接器,简化原型设计并减少错误。
SEN-14843 价格&库存
很抱歉,暂时无法提供与“SEN-14843”相匹配的价格&库存,您可以联系我们找货
