SparkFun gator:starter ProtoSnap
SEN-14891
The SparkFun gator:starter ProtoSnap is one of a series of gator-clippable accessories called
gator:boards that have been created to directly interface with the micro:bit or to other micro
controllers! The gator:starter ProtoSnap provides you with a starting point to go beyond the
capabilities of the micro:bit, with three different boards that can be kept as a whole or broken apart
for individual use!
Included on each gator:starter is a temperature sensor board, a light sensor board and an RGB LED
board. Since this is a ProtoSnap, we’ve broken out the power so it can be clipped to on the edge of
the gator:starter to power the board without breaking each individual sensor or LED. Snapping the
board apart can be easily done by twisting each of the LED boards side to side until it pops out and
will need to be done if you want to light any of the LEDs on their own.
There are also power tabs available on the two sensors and the LED if you choose to break the
gator:starter into its basic components. If you don’t break the board apart however, you’ll still be able
to interface with all of the sensor and light pins, which are broken out with a dual hole design to allow
clipping from above.
INCLUDES
Included on the ProtoSnap
1x gator:temperature Board (MCP9700)
1x gator:light Board (TEMT6000)
1x gator:RGB Board
https://www.sparkfun.com/products/14891?_ga=2.74471314.1233167554.1540313754‐1018459942.1513696581 10‐23‐18
很抱歉,暂时无法提供与“SEN-14891”相匹配的价格&库存,您可以联系我们找货
