PocketLab Voyager
SEN-15012
The PocketLab Voyager is an all-in-one science lab that is capable enough for a professional
engineer and simple enough for a 4th grade student. The Voyager can detect and measure multiple
forms of sensor data including motion, light, magnetic fields, and weather. You can also attach an
external temperature probe as well but one is not included in this kit. The Voyager has been
designed to work with either the PocketLab or VelocityLab apps by streaming real time data from it’s
multiple sensors to your iOS, Android, ChromeBook, or Windows device where you can view, graph,
record, and save data as a spreadsheet. This version of the PocketLab is great for physical science,
weather and climate studies, engineering projects and more.
The PocketLab Voyager includes an optical range finder that works from as low as 10cm and all the
way up to 2 meters, and is perfect for measuring the speed and position of moving objects like
physics carts or falling objects. Additionally, the PocketLab Voyager has on board memory to store
30,000 data points. This can be used for situations where your device is out of range of the module
like weather balloons, high altitude rockets, underwater devices, or installed at a remote weather
station.
INCLUDES
1x PocketLab Voyager
1x Carrying Case
1x USB Cable
1x Getting Started Guide
1x PocketLab Sticker
FEATURES
Wireless Connection: Bluetooth 4.0
Battery: Rechargeable via micro USB
Battery Life:
o 8hrs (wireless, full data rate)
o 12hrs (low power, logging mode)
Wireless Range: 250 feet line-of-sight
Memory: 30,000 data readings
Durability: 2m (6ft) drop protection
Dimensions: 3.8cm x 3.8cm x 1.5cm (1.5in x 1.5in x 0.6in)
Weight: 17g (0.6oz)
Accelerometer
o Range: ±16g
o Resolution: 0.008g @ 94Hz
o Data Rate:
50 samples/sec (real-time)
200 samples/sec (coming soon in burst mode)
Gyroscope
o Range: ±2000 deg/sec
o Resolution: 0.1 deg/sec @ 92Hz
o Data Rate:
Magnetometer
o Range: ±4800uT
o Resolution: 0.15uT
o Data Rate: 50 samples/sec
Barometric Pressure
o Range: 30 - 180kPa
o Pressure Resolution: 1.3Pa
o Absolute Accuracy: 0.1kPa
Humidity
o Range: 0-100%RH
o Resolution: 0.02%RH
o Absolute Accuracy: 3%RH
Light
o Range: 0.01 - 64,000 Lux
o Spectrum: 400nm - 1000nm (Visible light)
o Data Rate: 30 samples/sec
Altitude
o Range: -5,300m - 9,500m (-17,400ft - 31,000ft)
o Resolution: 11cm (4in)
o Absolute Accuracy: 10m (33ft)
Ambient Temperature
o Range: -40C - 85C (-40F - 185F)
o Resolution: 0.01 C (0.02 F)
o Absolute Accuracy: 0.5C (0.9F)
IR Range
o Range: 2m typical, 1.5m minimum (indoors)
o Resolution: 1cm (0.4in)
o Absolute Accuracy: 5% of reading
o Data Rate: 33 samples/sec
o Field of View: 25 degrees
https://www.sparkfun.com/products/15012 10-29-18
很抱歉,暂时无法提供与“SEN-15012”相匹配的价格&库存,您可以联系我们找货
