SparkFun Triad Spectroscopy Sensor - AS7265x (Qwiic)
SEN-15050
The SparkFun Triad Spectroscopy Sensor is a powerful optical inspection sensor. Three AS7265x
spectral sensors are combined alongside a visible, UV, and IR LEDs to illuminate and test various
surfaces for light spectroscopy. The Triad is made up of three sensors; the AS72651, the AS72652,
and the AS72653 and can detect the light from 410nm (UV) to 940nm (IR). In addition, 18 individual
light frequencies can be measured with precision down to 28.6 nW/cm2 and accuracy of +/-12%.
Utilizing our handy Qwiic system, no soldering is required to connect it to the rest of your system.
However, we still have broken out 0.1"-spaced pins in case you prefer to use a breadboard.
The SparkFun Triad Spectroscopy Sensor communicates over I2C by default or over 115200bps
serial. We’ve written a fully formed Arduino library to access all the various features include taking
readings and illuminating LEDs all over the Qwiic I2C interface. In addition, the Triad can be setup to
communicate over serial. The serial interface uses an AT command set.
What can you do with light spectroscopy? It’s an amazing field of study, and the SparkFun Triad
brings what used to be prohibitively expensive equipment to the desktop. The AS7265x should not
be confused with highly complex photon spectrometers, but the sensor array does give the user the
ability to measure and characterize how different materials absorb and reflect 18 different
frequencies of light. We’ve also written a full Arduino library that makes reading and interacting with
the Triad simple and easy!
The SparkFun Qwiic Connect System is an ecosystem of I2C sensors, actuators, shields and cables
that make prototyping faster and less prone to error. All Qwiic-enabled boards use a common 1mm
pitch, 4-pin JST connector. This reduces the amount of required PCB space, and polarized
connections mean you can’t hook it up wrong.
FEATURES
Selectable interface: I2C or Serial (115200bps)
18 frequencies of light sensing from 410nm to 940nm
28.6 nW/cm2 per count
Accuracy of +/-12%
Integrated 405nm UV, 5700k White, and 875nm IR LEDs
Software control over each illumination LED as well as current control
Optional external bulb or illumination control
Programmed with latest firmware from AMS
https://www.sparkfun.com/products/15050 11‐12‐18
很抱歉,暂时无法提供与“SEN-15050”相匹配的价格&库存,您可以联系我们找货
