SEN-15171
SEN-15171
    SPARKFUNELECTRONICS
    ZIO ULTRASONIC DISTANCE SENSOR -
SEN-15171 数据手册
    Zio Ultrasonic Distance Sensor - HC-SR04 (Qwiic) SEN-15171   You may be familiar with the classic HC-SR04 distance sensor, it is great for providing non-contact distance readings from 2cm to 400cm. This board improves on the classic by adding a Qwiic connector to it, so now you can communicate over I2C. If you prefer to bypass the Qwiic connector and I2 you can also access the Trigger and Echo pins which are broken out on the edge of the boa The SparkFun Qwiic Connect System is an ecosystem of I2C sensors, actuators, shields and cables that make prototyping faster and less prone to error. All Qwiic-enabled boards use a common 1mm pitch, 4-pin JST connector. This reduces the amount of required PCB space, and polarized connections mean you can’t hook it up wrong. INCLUDES   1x Ultrasonic Distance Sensor - HC-SR04 1x Right-Angle Header - 4-pin FEATURES         Operating Voltage 3.3V Detecting Angle: 15 degrees Sensor range: 2cm to 400cm Accuracy: 3mm MCU on board: STM8L051 Default I2C Address: 0x00 Dimensions: 21.5 x 45.5mm Weight 9.2g                                                   https://www.sparkfun.com/products/15171/3‐1‐19
SEN-15171 价格&库存
很抱歉,暂时无法提供与“SEN-15171”相匹配的价格&库存,您可以联系我们找货
