SEN-15219
SEN-15219
    SPARKFUNELECTRONICS
    MAX30101,MAX32664 - 医疗,保健和健身 评估板 - 传感器
SEN-15219 数据手册
      SparkFun Pulse Oximeter and Heart Rate Sensor ‐ MAX30101  & MAX32664 (Qwiic)  SEN-15219 Open Source Hardware The SparkFun Pulse Oximeter and Heart Rate Sensor is an I2C based biometric sensor, utilizing two chips from Maxim Integrated: the MAX32664 Biometric Sensor Hub and the MAX30101 Pulse Oximetry and Heart Rate Module. While the latter does all the sensing, the former is an incredibly small and fast Cortex M4 processor that handles all of the algorithmic calculations, digital filtering, pressure/position compensation, advanced R-wave detection, and automatic gain control. We've provided a Qwiic connector to easily connect to the I2C data lines but you will also need to connect to two additional lines. This board is very small, measuring at 1in x 0.5in (25.4mm x 12.7mm), which means it will fit nicely on your finger without all the bulk. The MAX30101 does all the sensing by utilizing its internal LEDs to bounce light off the arteries and arterioles in your finger's subcutaneous layer and sensing how much light is absorbed with its photodetectors. This is known as photoplethysmography. This data is passed onto and analyzed by the MAX32664 which applies its algorithms to determine heart rate and blood oxygen saturation (SpO2). SpO2 results are reported as the percentage of hemoglobin that is saturated with oxygen. It also provides useful information such as the sensor's confidence in its reporting as well as a handy finger detection data point. To get the most out of the sensor we've written an Arduino Library to make it easy to adjust all the possible configuratio The SparkFun Qwiic connect system is an ecosystem of I2C sensors, actuators, shields and cables that make prototyping faster and less prone to error. All Qwiic-enabled boards use a common 1mm pitch, 4-pin JST connector. This reduces the amount of required PCB space, and polarized connections mean you can’t hook it up wrong. SparkFun Pulse Oximeter and Heart Rate Sensor    MAX30101 and MAX32664 sensor and sensor hub Qwiic connectors for power and I2C interface I2C Address: 0x55 MAX30101 - Pulse Oximeter and Heart-Rate Sensor      Heart-Rate Monitor and Pulse Oximeter Sensor in LED Reflective Solution Integrated Cover Glass for Optimal, Robust Performance Ultra-Low Power Operation for Mobile Devices Fast Data Output Capability Robust Motion Artifact Resilience MAX32664 - Ultra-Low Power Biometric Sensor Hub     Biometric Sensor Hub Solution Finger-Based Algorithms Measure Pulse Heart Rate and Pulse Blood Oxygenation Saturation (SpO2) Both Raw and processed data are available Basic Peripheral mix optimizes size and performance               https://www.sparkfun.com/products/15219/9‐24‐19
SEN-15219
物料型号为MAX30101和MAX32664。
MAX30101是一款心率监测和脉搏血氧仪传感器,它使用内部LED通过光的反射来测量手指的动脉和毛细血管层,并通过光电探测器测量光的吸收量,这个过程称为光电容积描记术。
MAX32664是一款超低功耗的生物传感器中心,它包含基于手指的算法来测量脉搏心率和脉搏血氧饱和度(SpO2),并提供原始和处理后的数据。
器件简介:SparkFun脉搏血氧仪和心率传感器是一个基于I2C的生物识别传感器,使用Maxim Integrated的两个芯片:MAX32664生物传感器中心和MAX30101脉搏血氧和心率模块。
MAX32664负责算法计算、数字滤波、压力/位置补偿、高级R波检测和自动增益控制。
引脚分配:该板具有Qwiic连接器,用于连接电源和I2C接口。
引脚包括GND、RST、SCL、SDA和3V3。
参数特性:MAX30101具有超低功耗操作,适用于移动设备,并且具有快速数据输出能力以及强大的运动伪影抗性。
MAX32664是一个生物传感器中心解决方案,具有优化大小和性能的基本外设混合。
功能详解:MAX30101通过其内部LED测量光的吸收量来执行传感,并将数据传递给MAX32664进行分析,以确定心率和血氧饱和度(SpO2)。
SpO2结果报告为氧合血红蛋白的百分比。
应用信息:该传感器可以用于监测心率和血氧饱和度,提供传感器对其报告的信心水平以及有用的手指检测数据点。
封装信息:该板非常小巧,尺寸为1英寸x 0.5英寸(25.4mm x 12.7mm),可以舒适地戴在手指上,没有笨重感。
SEN-15219 价格&库存
很抱歉,暂时无法提供与“SEN-15219”相匹配的价格&库存,您可以联系我们找货
SEN-15219
