SEN-15276
SEN-15276
    SPARKFUNELECTRONICS
    SPARKFUN LIGHTNING DETECTOR - AS
SEN-15276 数据手册
      SparkFun Lightning Detector - AS3935 (Qwiic) SEN-15276   The SparkFun Qwiic Lightning Detector adds lightning detection to your next weather station to make sure you are aware of any potential hazardous weather heading your way. The AS3935 is capable of detecting lightning up to 40km away with an accuracy of 1km to the storm front with a sensitive antenna tuned to pick up lightning events in the 500kHz band. Utilizing our handy Qwiic system, no soldering is required to connect it to the rest of your system. However, we still have broken out 0.1"-spaced pins in case you prefer to use a breadboard. There are a number of sources that can cause false positives but the lightning detector itself can reliably filter these out by default. If not, we've made sure to include settings you can configure using the lightning detector library to increase the chip's robustness to noise and false positives. The lightning detector library also gives you access to settings such as storm sensing sensitivity when detecting indoors vs outdoors, or the number of lightning strikes needed to trigger an interrupt. The SparkFun Qwiic connect system is an ecosystem of I2C sensors, actuators, shields and cables that make prototyping faster and less prone to error. All Qwiic-enabled boards use a common 1mm pitch, 4-pin JST connector. This reduces the amount of required PCB space, and polarized connections mean you can’t hook it up wrong. Features    Lightning Sensing o 40 km Range with accuracy of 1km in 14 steps Features o Programmable Detection Levels o Distance to storm estimation o "Disturber" (false event) rejection algorithm o Indoor and Outdoor Settings o SPI and I2C Interfaces o I2C Address: 0x03 (Optional: 0x02, 0x01, 0x00) o Qwiic Enabled Operating Range o Supply Voltage: 2.4V - 5.5V             https://www.sparkfun.com/products/15276/4-22-19
SEN-15276 价格&库存
很抱歉,暂时无法提供与“SEN-15276”相匹配的价格&库存,您可以联系我们找货
