SparkFun Capacitive Touch Slider - CAP1203 (Qwiic)
SEN-153 4 4
Do you want to replace a slider or a button on your art project or science experiment with a more
interesting interface? This Capacitive Touch Slider is a "Qwiic" and easy way to add capacitive touch
to your next project. With the board's built in touch pads, you can immediately start playing with the
touch capabilities as three unique touch inputs or as a slider. You can also enable a touch input to
act as a power button, customize the sensitivity for your own touch pads, and play with the interrupt
alert LED. Utilizing our Qwiic system, no soldering is required to connect it to the rest of your system.
However, we have broken out 0.1"-spaced pins in case you prefer to use a breadboard or create
your own touch pads.
On the front of the board, there is an arrow shape which contains three separate capacitive touch
pads. We also broke out the capacitive touch sensor lines as plated through-holes on the top of the
board. You can use these pins to connect to your own capacitive touch pads. The CS1 pin connects
to the left pad, the CS2 pin connects to the middle pad, and the CS3 pin connects to the right pad.
The SparkFun Qwiic connect system is an ecosystem of I2C sensors, actuators, shields and cables
that make prototyping faster and less prone to error. All Qwiic-enabled boards use a common 1mm
pitch, 4-pin JST connector. This reduces the amount of required PCB space, and polarized
connections mean you can’t hook it up wrong
FEATURES
Capacitive Touch
o
3 unique capacitive touch inputs
o
o
o
o
o
o
Emulated slider
Power button setting
Programmable sensitivity
Automatic recalibration
I2C Address: 0x28
Qwiic Enabled
Features
Operating Range
o
Supply Voltage: 3.3V - 5V
https://www.sparkfun.com/products/15344/6‐12‐19
很抱歉,暂时无法提供与“SEN-15344”相匹配的价格&库存,您可以联系我们找货
