SparkFun Lightning Detector - AS3935
SEN-15441
The SparkFun Lightning Detector adds lightning detection to your next weather station to make sure
you are aware of any potential hazardous weather heading your way. The AS3935 is capable of
detecting lightning up to 40km away with an accuracy of 1km to the storm front with a sensitive
antenna tuned to pick up lightning events in the 500kHz band.
There are a number of sources that can cause false positives but the lightning detector itself can
reliably filter these out by default. If not, we've made sure to include settings you can configure using
the lightning detector library to increase the chip's robustness to noise and false positives. The
lightning detector library also gives you access to settings such as storm sensing sensitivity when
detecting indoors vs outdoors, or the number of lightning strikes needed to trigger an interrupt.
FEATURES
Lightning Sensing
o 40km Range with accuracy of 1km in 14 steps
Features
o Programmable Detection Levels
o Distance to storm estimation
o "Disturber" (false event) rejection algorithm
o Indoor and Outdoor Settings
o SPI Interface
Operating Range
o Supply Voltage: 2.4V - 5.5V
https://www.sparkfun.com/products/15441/7‐30‐19
很抱歉,暂时无法提供与“SEN-15441”相匹配的价格&库存,您可以联系我们找货
