SEN-15892
SEN-15892
    SPARKFUNELECTRONICS
    ATtiny85 声音 传感器 Qwiic 平台评估扩展板
SEN-15892 数据手册
    Zio Qwiic Loudness Sensor SEN-15892 The Zio Qwiic Loudness Sensor is an I2C device making it easy to measure the noise level in your next project. No soldering required. The Loudness sensor can output ADC value (0-1023) to tell you the level of the noise. Also you can use this ADC value in other projects, like a sound sensor. The loudness value strongly depends on the distance between the sound source and the sensor. The SparkFun Qwiic Connect System is an ecosystem of I2C sensors, actuators, shields and cables that make prototyping faster and less prone to error. All Qwiic-enabled boards use a common 1mm pitch, 4-pin JST connector. This reduces the amount of required PCB space, and polarized connections mean you can’t hook it up wrong. FEATURES    Gateway MCU: ATTINY85-20SU I2C address: 0x07- 0x78 (Default:0x38) Loudness rate Range: 0-1023 https://www.sparkfun.com/products/15892/1‐6‐20
SEN-15892 价格&库存
很抱歉,暂时无法提供与“SEN-15892”相匹配的价格&库存,您可以联系我们找货
