SEN-16408
SEN-16408
    SPARKFUNELECTRONICS
    电流检测 电源管理 评估板
SEN-16408 数据手册
  KR Sense Current and Voltage Sensor - 90A SEN-16408 The KR Sense 90A is a small voltage and current sense breakout board. DC current is determined by measuring a voltage drop across a parallel shunt resistor, then converted to a final analog voltage output by the INA-169. Voltage sense is accomplished by scaling to 3.3V ADC range by a precision resistor divider. This version of the sensor features a maximum voltage tolerance of 51.8 Volts at 89.4 Amps, to be exact. Please be aware that KR Sense boards are supplied without leads or connectors. The pad sizes are large enough to accommodate 12 gauge heavy duty leads but care must be exercised when soldering. Smaller gauge leads are considerably easier to solder without creating shorts. This product is compatible with the Attopilot 90A Voltage and Current Sensor Breakout. FEATURES       Input resistor divider scaled for 13.6V Input voltage (recommended) for 3.3V output 51.8V Max 89.4A Max Very low zero current offset Analog current output scaled for 3.3V ADC Self Powered https://www.sparkfun.com/products/16408/3‐18‐20
SEN-16408 价格&库存
很抱歉,暂时无法提供与“SEN-16408”相匹配的价格&库存,您可以联系我们找货
SEN-16408
  • 1+191.603751+22.99895
库存:5
