SEN-21231
SEN-21231
    SPARKFUNELECTRONICS
    - 图像传感器 评估板 - 传感器
SEN-21231 数据手册
Person Sensor by Useful Sensors SEN-21231 Add advanced computer vision capabilities to your project, without the coding. The Person Sensor from Useful Sensors Inc. includes a camera module pre-programmed with algorithms that detect nearby faces, and return information over a simple Qwiic I 2C interface. It is designed to be used as an input to a larger system and be treated like any other sensor where power and information are provided through SparkFun's Qwiic I 2C interface. There’s also a separate interrupt pin, TP1, which is used to indicate if any people have been detected. Internally the Person Sensor bundles an image sensor and a small microcontroller into a single board. It is a small, low power (~150 milliwatts), and economical hardware module that is capable of detecting nearby faces and returning information about how many there are, where they are relative to the device, and performs facial recognition. This makes it easy to build projects that wake up when people approach, follow their faces, mute a microphone when nobody is present, and even recognize different people to personalize their experiences. The Person Sensor is designed to be a simple way to build smarter devices. https://www.sparkfun.com/products/21231 12-1-2022
SEN-21231 价格&库存
很抱歉,暂时无法提供与“SEN-21231”相匹配的价格&库存,您可以联系我们找货
SEN-21231
    • 1+224.18640
    • 200+89.45640
    • 500+86.46480
    • 1000+84.98520
