SPX-14804
SPX-14804
    SPARKFUNELECTRONICS
    ATTO84 WITH ARDUINO BOOTLOADER
SPX-14804 数据手册
      Atto84 with Arduino Bootloader  SPX-14804 ROHS Arduino and Arduino compatible dev boards are an awesome tool for developing an idea quickly but, being development boards, they're often a little more bulky and full featured than you really need. Having a USB interface and a bootloader is so nice, though, so we put together the bare minimum Arduino compatible breakout for integration into your small projects. We call it the Atto84. The Atto84 is essentially a breakout board for the absolutely minute WQFN ATtiny84, but we've done some work to make it easier to program. First off, we've added a micro-USB connector and a firmware-based USB driver for the ATtiny that allows you to program the chip over USB. In addition, we've created an Arduino board profile that combines this bootloader with an extremely fullfeatured ATtiny Arduino core. Simply install the USB drivers on your computer, select the board profile from Arduino's Board Manager and upload code to this board like any other Arduino style development board. There are very tiny silkscreen pin labels on the top of the board (which correspond to the Arduino pin numbers, not the IC pin numbers) and larger labels on the bottom side of the board. A reset button allows you to put the board into bootloader mode for programming and an on-board LED attached to pin 8 makes for a handy status indicator for your project. Thin pcb construction and castellated headers make the Atto84 very low-profile but the addition of 0.1" pin headers turns it into a handy, breadboard-friendly, package. Experimental Product: SparkX products are rapidly produced to bring you the most cutting edge technology as it becomes available. These products are tested but come with no guarantees. Live technical support is not available for SparkX products. Head on over to our forum for support or to ask a question. FEATURES     Only 28x11mm and 3.5mm tall! Upload Arduino code via USB 12 position, 0.4 x 0.1" DIP package Flat bottom and castellated headers for surface mounting                  https://www.sparkfun.com/products/14804/12‐3‐19
SPX-14804 价格&库存
很抱歉,暂时无法提供与“SPX-14804”相匹配的价格&库存,您可以联系我们找货
