SPX-15034
SPX-15034
    SPARKFUNELECTRONICS
    SPARKX SAMD21 PRO RF 1W
SPX-15034 数据手册
  SparkX SAMD21 Pro RF 1W SPX-15034 LoRa stands for ‘Long-Range,’ referring to a modulation technique whose specialty is low power transmission of small data packets – perfect for Internet of Things applications. Using either point-topoint radio or LoRaWAN you can send data from a node in a remote location back to your base station to check in on sensors or track equipment. Communication is possible in the other direction as well to send commands or control actuators! This is the updated version (x02) of the original. We’ve removed the battery charger so that you can now power it with up to 15 volts in the field, removed a redundant U.FL connection for cleaner RF output, and most importantly exposed the flash memory on a separate SPI port. This makes the board compatible with Micro/CircuitPython while still being able to run the radio module.     Like the LoRa®-enabled SparkX Pro RF this board is based on the Semtech SX1276 transceiver, but the module boasts a whopping 1W output power. All that extra oomph makes it possible to send small messages up to 9 miles using common rubber-duck type antennas. In addition to more transmission power the SparkX SAMD21 ProRF 1W gets more computational power courtesy of the SAMD21 microcontroller running at 48 MHz. We used the additional GPIO pins to permanently enable LoRaWAN signals. This means more pins for you to connect to sensors and actuators, even when connecting to a LoRaWAN network like The Things Network. Checkout the SAMD21 Mini/Dev Breakout Hookup Guide as a general starting point for the SAMD21 Pro RF 1W. To get you started we’ve included some basic Point-2-Point examples. Experimental Product: SparkX products are rapidly produced to bring you the most cutting edge technology as it becomes available. These products are tested but come with no guarantees. Live technical support is not available for SparkX products. Head on over to our forum for support or to ask a question. SPI Silkscreen Mis-label The top side silkscreen tag for SPI (not SPI1) should read MISO MOSI SCLK from left to right. (Instead it reads MOSI MISO SCLK). The labels are correct on the bottom side.     https://www.sparkfun.com/products/15034 11-12-18
SPX-15034 价格&库存
很抱歉,暂时无法提供与“SPX-15034”相匹配的价格&库存,您可以联系我们找货
