SPX-15074
SPX-15074
    SPARKFUNELECTRONICS
    HUMIDITY SENSOR BREAKOUT SHTC3
SPX-15074 数据手册
  SparkX Humidity Sensor Breakout SHTC3 (Qwiic) SPX-15074 ROHS Sensirion’s SHTC3 digital humidity sensor builds on the success of their SHTC1 sensor. The SHTC3 has a broader supply voltage range (1.62V to 3.6V) and higher accuracy (±2% RH, ±0.2°C) than its predecessor, enabling greater flexibility. The SHTC3 is low cost, easy-to-use, highly accurate, digital humidity and temperature sensor. This sensor is ideal for environmental sensing and data logging and perfect for build a weather stations or humidor control system. All you need are two lines for I2C communication, and you’ll have relative humidity readings and very accurate temperature readings as a bonus! Hook up is a breeze with as the breakout board is using the Qwiic connect system. The breakout board has built-in 2.2kΩ pullup resistors for I2C communications. If you’re hooking up multiple I2C devices on the same bus, you may want to disable these resistors. Experimental Product: SparkX products are rapidly produced to bring you the most cutting edge technology as it becomes available. These products are tested but come with no guarantees. Live technical support is not available for SparkX products. Head on over to our forum for support or to ask a question.         https://www.sparkfun.com/products/15074 11-12-18
SPX-15074 价格&库存
很抱歉,暂时无法提供与“SPX-15074”相匹配的价格&库存,您可以联系我们找货
