SPX-15508
SPX-15508
    SPARKFUNELECTRONICS
    QWIIC THERMOCOUPLE AMPLIFIER - M
SPX-15508 数据手册
      Qwiic Thermocouple Amplifier - MCP9600 SPX-15508 ROHS The MCP9600 is a high accuracy thermocouple amplifier equipped with an I2C interface, accessed over our Qwiic system. Inside the chip are two temperature sensors, one for the thermocouple itself (the hot junction) and one for the chip itself (the cold junction). As a result, the MCP9600 can read both the ambient temperature and the temperature of whatever you're trying to measure! The MCP9600 can do both with a resolution of 0.0625°C, and an accuracy of ±1.5°C (worst-case). This board comes ready to accept a K-type thermocouple, which gives a temperature range of -200°C to 1350°C! This makes it perfect for a variety of applications, from measuring the temperature of your Crock-Pot to making sure your backyard induction furnace is up to temperature. In addition, the MCP9600 has four onboard temperature alerts that you can configure! Instead of constantly polling the sensor over I2C, you can set a temperature limit to trigger an interrupt when the temperature reaches a certain value. This frees up your microcontroller and your I2C bus to do more important things. It's also possible to put the MCP9600 into alternate operation modes in order to save power. The sensor supports a burst mode, where it will take a specifiable number of samples, return the results, and then go to sleep. This low-power mode makes the MCP9600 perfect for portable applications! We've written an Arduino library to help you get started quickly. You can download the library through the Arduino library manager by searching 'SparkFun MCP9600' or you can get the GitHub repo as a .zip file and install the library from there. This board is one of our many Qwiic compatible boards! Simply plug and go. No soldering, no figuring out which is SDA or SCL, and no voltage regulation or translation required! We do not plan to regularly produce SparkX products, so get them while they’re hot! Experimental Product: SparkX products are rapidly produced to bring you the most cutting edge technology as it becomes available. These products are tested but come with no guarantees. Live technical support is not available for SparkX products. Head on over to our forum for support or to ask a question.   https://www.sparkfun.com/products/15508/7‐30‐19
SPX-15508 价格&库存
很抱歉,暂时无法提供与“SPX-15508”相匹配的价格&库存,您可以联系我们找货
