Qwiic Iridium 9603N
SPX-15780
With a clear view of the sky, the Qwiic Iridium 9603 allows you to send and receive short messages.
It works anywhere in the world, far beyond the reach of WiFi and GSM networks. Maybe you want to
transmit weather information from a weather station on top of a mountain? Or use it to send data
from a travelling balloon sat? Perhaps you need to communicate in an emergency, when other
networks might not be available?
At the heart of our product is an Iridium 9603 modem. The Qwiic module hosts the 9603 and
provides it with an antenna, and its power supply requirements. The modem’s serial interface is
translated into I2C commands by the ATtiny841 microcontroller.
Sending and receiving messages to the Iridium network is as easy as sending I2C commands from
your RedBoard over a Qwiic connector. The Arduino library walks you through sending messages to
the Iridium network using your Qwiic Iridium 9603. An online portal allows you to send messages
from the Iridium satellite network to your modem.
The Qwiic Iridium was designed by Paul Clark who wanted to be able to use the 9603N Short Burst
Data modem on Qwiic projects. Paul has also adapted the Iridium SBD library for I2C. For now, we
don’t have the licensing to sell this board along with the modem. So you need to buy a RockBLOCK
9603 to get the Iridium modem and Maxtena Iridium antenna for a full transceiver system.
Note: The Iridium modem does require a monthly rental service to exchange information with the
Iridium satellite network. You only pay for months in which you wish to use the modem. No annual
contract is required. Line rental costs £12GBP (about $15USD) per month and includes access to
the RockBLOCK management system for managing your devices. The billing system is built-in, and
allows you to pay for only what you use. Airtime for Iridium modems must be purchased from Rock
Seven via the admin portal once the units are registered. You cannot use the devices with another
Iridium airtime provider by default. If you would like to use it with another provider, you will need to
pay an unlock fee of $60USD per modem.
Experimental Product: SparkX products are rapidly produced to bring you the most cutting edge
technology as it becomes available. These products are tested but come with no guarantees. Live
technical support is not available for SparkX products. Head on over to our forum for support or to
ask a question.
https://www.sparkfun.com/products/15780 /11‐22‐19
很抱歉,暂时无法提供与“SPX-15780”相匹配的价格&库存,您可以联系我们找货
