SPX-15804
SPX-15804
    SPARKFUNELECTRONICS
    QWIIC IR BREAKOUT
SPX-15804 数据手册
      Qwiic IR Breakout  SPX-15804 ROHS Have you ever needed to monitor your yogurt in the community fridge because there’s a yogurt thief loose at work? Or have you ever needed the lights to flick on when walking in a room because your hands were full of groceries? The Qwiic IR breakout is the solution to all your people-detecting needs. This board utilizes Kemet Corporation’s lensless passive infrared sensor, PL-N823. It uses the pyroelectric effect of ceramic by absorbing infrared rays emitted from the human body. This sensor has a 60 degree viewing angle, low power consumption, and low profile which makes it ideal for gathering visual requirements. Though this is a lensless infrared sensor, placing the sensor behind a material like glass, acrylic, or polyethylene may amplify the distance at which it can detect. The detecting distance varies by what material is used, but the PL-N823 can detect up to 2 meters. We’ve written some example code using the ADS1015 library. The qwiic IR breakout board includes an ADC which quantifies the amplified source voltage of the IR sensor. There’s also a rudimentary peak detection example that could notify the user when someone waves their hand across the sensor. We do not plan to regularly produce SparkX products so get them while they’re hot! Experimental Product: SparkX products are rapidly produced to bring you the most cutting edge technology as it becomes available. These products are tested but come with no guarantees. Live technical support is not available for SparkX products. Head on over to our forum for support or to ask a question. DOCUMENTS       Datasheet Product Description Qwiic IR Breakout Examples Schematic Github Eagle Files            https://www.sparkfun.com/products/15804/12‐3‐19
SPX-15804 价格&库存
很抱歉,暂时无法提供与“SPX-15804”相匹配的价格&库存,您可以联系我们找货
