SPX-16298
SPX-16298
    SPARKFUNELECTRONICS
    QWIIC PRESSURE/HUMIDITY/TEMP (PH
SPX-16298 数据手册
          Qwiic Pressure/Humidity/Temp (PHT) Sensor ‐ MS8607  SPX-16298 ROHS The MS8607 from TE is an impressive combination pressure, humidity, temperature (PHT) sensor with accuracy of ±2mbar pressure, ±3% humidity, and ±1°C. Perfect for sensing general weather conditions the MS8607 really shines for high altitude, low pressure applications. Capable of sensing down to 10mbar, this pressure sensor separates itself from many other I2C pressure sensors like the BME280. The MS8607 is simple to use and gives the user some very powerful readings with very little power and conversion time. Hook up is a breeze with as the breakout board is using the Qwiic connect system. We have a fully formed Arduino library and extensive examples to get you up and running quickly. The breakout board has builtin 2.2kΩ pullup resistors for I2C communications. If you’re hooking up multiple I2C devices on the same bus, you may want to disable these resistors. Experimental Product: SparkX products are rapidly produced to bring you the most cutting edge technology as it becomes available. These products are tested but come with no guarantees. Live technical support is not available for SparkX products. Head on over to our forum for support or to ask a question. FEATURES  Operating Range:  o 10 - 2000mbar o 0 - 100% Humidity o -40 - 85°C Accuracy (at 25°C):  o ±2mbar pressure o ±3% humidity o ±1°C Resolution:  o 0.016 mbar o 0.04 % Humidity o 0.01 C Supply Current (1Hz, 1024 OSR): 0.78uA   Standby Current: 0.03uA Conversion Time (PHT): 4ms         https://www.sparkfun.com/products/16298/2‐24‐20
SPX-16298 价格&库存
很抱歉,暂时无法提供与“SPX-16298”相匹配的价格&库存,您可以联系我们找货
