TOL-14167
TOL-14167
    SPARKFUNELECTRONICS
    BATT CHRGR USB POWER PACK 5V 1A
TOL-14167 数据手册
Lithium Ion Battery Pack - 5Ah (USB) TOL-14167 RoHS Description: Power on the go? Why didn’t you ask? We’ve got plenty! These portable, rechargeable lithium ion battery packs are simple, compact and make for a great way to power your widgets in the field. Best of all, they’re dead simple to operate: just connect your device to the USB-A port on the battery pack, and that’s it! A four-tier status LED will alert you to the charge level of the battery and start powering your device. Each battery pack is equipped with an attached microUSB to charge your chosen device. To recharge the battery pack, just plug it into your computer or phone charger using the included USB micro-B cable. This particular battery pack has a 5,000mAh capacity and will source 1,000mA at 5VDC. We use these battery packs almost exclusively in our Spectacle product line, though we are sure you can find plenty of other uses for them! Note: This item may take longer to process due to battery installed in the equipment and therefore does not qualify for same-day shipping policy. Sorry for any inconvenience this may cause. Dimensions: 130mm x 67.5mm x 9mm https://www.sparkfun.com/products/14167 5-15-17
TOL-14167 价格&库存
很抱歉,暂时无法提供与“TOL-14167”相匹配的价格&库存,您可以联系我们找货
