TOL-14456
TOL-14456
    SPARKFUNELECTRONICS
    铁 60W 110V
TOL-14456 数据手册
    Soldering Iron ‐ 60W (Adjustable Temperature) TOL-14456   This adjustable-temperature soldering iron is a great tool for when you don’t want to break the bank but need a reliable iron to get the job done. Operating at 60W and 110V, this soldering iron can be adjusted to five different temperatures: 280°C, 330°C, 380°C, 430°C and 480°C. This iron is very easy to use and features an on/off switch, allowing you to keep it plugged in on your workbench stand for quick access. Each adjustable-temperature soldering iron is equipped with a 130cm (~51") power cord that is terminated with a North American standard type B plug. Additionally, the soldering tip can be replaced with Hakko brand tips to give your new iron plenty of different options!      Operating Voltage: 110VAC Wattage: 60W Five Adjustable Temperatures: 280°C – 480°C Cable Length: 130cm Hakko Tip Compatible        https://www.sparkfun.com/products/14456 11‐6‐17
TOL-14456 价格&库存
很抱歉,暂时无法提供与“TOL-14456”相匹配的价格&库存,您可以联系我们找货
