TOL-14806
TOL-14806
    SPARKFUNELECTRONICS
    SHAPEOKO TOUCH PROBE
TOL-14806 数据手册
            Shapeoko Touch Probe TOL-14806 The Touch Probe from Carbide 3D is a small accessory piece for your Shapeoko CNC machine meant to assist in finding the edges, or datums of the part you are milling. This part is an active probe, and when contacted to ground, communicates its position to the Carbide Motion program to help you fabricate easier. Carbide Motion supports the 4 different types of probing: XYZ (otherwise known as corner probing), X (to find the left edge of your material), Y (to find the front edge of your material), and Z (to find the top of your material). All instructions and software support material can be found in the Documents tab above. Note: The Shapeoko Touch Probe is only supported in Carbide Motion 4 and GRBL 1.1. This is only a software and firmware change, so no new hardware is required        https://www.sparkfun.com/products/14806 7‐18‐18
TOL-14806 价格&库存
很抱歉,暂时无法提供与“TOL-14806”相匹配的价格&库存,您可以联系我们找货
