TOL-14818
TOL-14818
    SPARKFUNELECTRONICS
    DRILL BIT VARIETY PCB 10PCS
TOL-14818 数据手册
Variety PCB Drill Set (10 Pieces) TOL-14818 This is variety PCB Drill Set from Carbide 3D that supplies you with more options for drilling into copper clad on your Shapeoko or Nomad CNC machines. Each set includes 10 unique PCB drills from 0.3mm to 1.2mm, each with a 0.125" shank. Additionally, each drill is made of solid carbide to ensure long lasting use. If you are wondering how best to utilize this kit, make sure to check out the free to use web app, Carbide Copper. Carbide Copper is CAM software to let you mill PCBs with your CNC machine and is the fastest way to make same-day circuit boards in your own office or shop. INCLUDES • • • • • • • • • • 1x 0.3mm PCB Drill 1x 0.4mm PCB Drill 1x 0.5mm PCB Drill 1x 0.6mm PCB Drill 1x 0.7mm PCB Drill 1x 0.8mm PCB Drill 1x 0.9mm PCB Drill 1x 1.0mm PCB Drill 1x 1.1mm PCB Drill 1x 1.2mm PCB Drill https://www.sparkfun.com/products/14818 8-6-18
TOL-14818 价格&库存
很抱歉,暂时无法提供与“TOL-14818”相匹配的价格&库存,您可以联系我们找货
