TOL-14854
TOL-14854
    SPARKFUNELECTRONICS
    END MILL CARBIDE 0.250" 2PK
TOL-14854 数据手册
      Flat Cutter - 0.25" Diameter, #201 (2 Pack) TOL-14854 This is a two pack of flat mills from Carbide 3D that are perfect for milling flat or prismatic surfaces. Each mill in this pack features a cutting and shank diameter of 0.25 inches and a cutting length of 0.75 inches. These cutters really are great for specialized 3D machining and fabrication. Each cutter is made of solid carbide to ensure long lasting use. Note: If you are using these cutters with a Nomad, you will also need a 0.25in collet. INCLUDES 2x Flat Cutter - 0.25in. Diameter FEATURES    Cutting Diameter: 0.25" Cutting Length: 0.75" Shank Diameter: 0.25" https://www.sparkfun.com/products/14854 10-4-18
TOL-14854 价格&库存
很抱歉,暂时无法提供与“TOL-14854”相匹配的价格&库存,您可以联系我们找货
