TOL-14856
TOL-14856
    SPARKFUNELECTRONICS
    END MILL CARBIDE 0.250" 2PK
TOL-14856 数据手册
        Zrn Coated Flat Cutter - 0.25" Diameter, #201Z (2 Pack) TOL-14856 This is a two pack of Zrn coated flat mills from Carbide 3D that are perfect for fabricating with aluminum. Each mill in this pack features a cutting and shank diameter of 0.25 inches and a cutting length of 0.75 inches. These cutters really are great for precision 3D machining and fabrication. These cutters are coated with Zirconium Nitride (Zrn). This is a specialty coating which makes it most suitable for temperature sensative materials. ZrN had excellent corrosion-resistance, lubricity and hardness to suit many applications. This coating has a unique ability to reduce the build-up edge on cutting tools which results in a better surface finish. ZrN works well for machining Titanium and Aluminum Alloys, Nickel, Brass, Copper, Cast Iron and Zinc. Each cutter is made of solid carbide to ensure long lasting use. INCLUDES  2x Zrn Coated Flat Cutter - 0.25in. Diameter FEATURES      Cutting Diameter: 0.25" Cutting Length: 0.75" Shank Diameter: 0.25" 3 Flute, center cutting 2.5" Overall Leng https://www.sparkfun.com/products/14856 10-4-18
TOL-14856 价格&库存
很抱歉,暂时无法提供与“TOL-14856”相匹配的价格&库存,您可以联系我们找货
