TOL-14859
TOL-14859
    SPARKFUNELECTRONICS
    END MILL CARBIDE 0.500" 2PK
TOL-14859 数据手册
  V-Bit Cutter - 0.5" Diameter, 60 Degree, #302 (2 Pack) TOL-14859 This is a two pack of V-Bit mills from Carbide 3D that are perfect for engraving intricate patterns and fine details. Each mill in this pack features a cutting diameter of 0.5 inches, a shank diameter of 0.25 inches, and a cutting angle of 60º. These cutters really are great for precision 3D machining and fabrication. Each cutter is made of solid carbide to ensure long lasting use. Note: If you are using these cutters with a Nomad, you will also need a 0.25in collet. INCLUDES  2x V-Bit Cutter - 0.5in. Diameter, 60 Degree FEATURES      Cutting Diameter: 0.5" Cutting Length: 0.25" Shank Diameter: 0.25" 60º Cutting Angle 2 Flute https://www.sparkfun.com/products/14859 10-4-18
TOL-14859 价格&库存
很抱歉,暂时无法提供与“TOL-14859”相匹配的价格&库存,您可以联系我们找货
