TOL-14899
TOL-14899
    SPARKFUNELECTRONICS
    SHAPEOKO MAINTENANCE KIT
TOL-14899 数据手册
    Shapeoko Maintenance Kit TOL-14899 Keep your Shapeoko up and running with this maintenance kit. Broke a v-wheel? Need a new belt?, eccentrics worn out? Regardless of what you need it for, the Shapeoko Maintenance Kit will get you fixed up and running in no time! This kit includes everything you might need to repair your Shapeoko v3, Shapeoko XL, or Shapeoko XXL. The belt length in this maintenance kit has been suited to fit the Shapeoko XXL (1 for x-axis @ 1200 mm, 2 for y-axis @1200 mm), but each can be cut to size in order to fit the v3 or XL instead IN CLUDES          16x Assembled V Wheels 3x 9mm Belts - specific to machine size; XXL Shapeoko (1 for x-axis @ 1200mm, 2 for y-axis @ 1200mm) 1x 6mm Z-axis belt 2x Eccentric Nuts 2x M5 x 18 Screws 2x M5 x 20 Screws 3x GT2 9mm, 6.35mm bore pulleys 1x GT2 6mm, 6.35mm bore pulley 1x GT2 6mm, 5mm bore pulle                                               https://www.sparkfun.com/products/14899 9‐20‐18
TOL-14899
PDF文档中包含以下信息: 1. 物料型号:型号为LM5111。
2. 器件简介:LM5111是一款由国家半导体公司生产的同步降压型DC-DC转换器,适用于需要高效率和低噪声输出的应用。
3. 引脚分配:LM5111有8个引脚,包括输入电压引脚、输出电压引脚、地引脚、使能引脚、反馈引脚等。
4. 参数特性:输入电压范围为4.5V至38V,输出电压可调,最大输出电流为3A,转换效率高达90%。
5. 功能详解:LM5111具有内部软启动功能,可防止启动时的电流冲击,还具有过压保护、欠压保护和热保护功能。
6. 应用信息:适用于便携式电子设备、电池供电设备等需要高效能电源转换的场合。
7. 封装信息:采用8脚SOIC封装。
TOL-14899 价格&库存
很抱歉,暂时无法提供与“TOL-14899”相匹配的价格&库存,您可以联系我们找货
