TOL-15003
TOL-15003
    SPARKFUNELECTRONICS
    MAGNETIC SCREWDRIVER 20PCS
TOL-15003 数据手册
      Magnetic Screwdriver Set (20 Piece) TOL-15003 ROHS   Let’s face it, everyone will need a screwdriver at some point so it is best to be as prepared as possible by having plenty of different driver bits available to you. This is a 20 piece screwdriver set that magnetically keeps each of the unused bits secured inside of a thin case that easily fits in your pocket. On top of all the bits and handle, this screwdriver set also comes with a pair of tweezers as well (these can really help getting the pieces out of the case). The Magnetic Screwdriver Set bits are made from S2 steel material with a hardness rating of 60HRC while the handle is completely made from an anti-rust aluminum allow making this entire set incredibly resistant to time and the elements!  INCLUDES                        1x Carrying Case 1x Screwdriver Handle 1x Tweezers 1x Phillips Head Bit #000 1x Phillips Head Bit #00 1x Phillips Head Bit #1 1x Phillips Head Bit #2 1x Phillips Head Bit #2.3 1x Flat Head Bit 1.0 1x Flat Head Bit 1.5 1x Flat Head Bit 2.5 1x Torx Bit T2 1x Torx Bit T3 1x Torx Bit T4 1x Torx Bit T5 1x Torx Bit T6H 1x Torx Bit T8H 1x Tri-Wing Bit Y1 1x Tri-Wing Bit Y0.6 1x Star Bit 0.8 1x Star Bit 1.2 1x Standoff Bit 2.5 1x Spanner Bit 2.0                                          https://www.sparkfun.com/products/15003/12‐10‐18
TOL-15003 价格&库存
很抱歉,暂时无法提供与“TOL-15003”相匹配的价格&库存,您可以联系我们找货
