TOL-15040
TOL-15040
    SPARKFUNELECTRONICS
    ZRN COATED FLAT CUTTER 2PK
TOL-15040 数据手册
      Zrn Coated Flat Cutter - 0.0625in. Diameter, #112-Z (2 Pack) TOL-15040 This flat mill is perfect for roughing or machining flat or primsatic parts. The cutter is coated with Ziconium Nitride, (ZrN). ZrN is a specialty coating that makes it exceptional for temperature sensitive materials. The coating has excellent corrosion-resistance, lubricity, and is hard enough to suit many different applications. ZrR coating has a unique ability to keep edge build-up to a minimum which makes for a better surface finish. Note: ZrN works best for machining Titanium and Aluminum Alloys, Nickel, Brass, Copper, Cast Iron and Zinc.  INCLUDES  2x Zrn Coated Flat Cutter - 0.0625in. Diameter  FEATURES    Cutting Diameter: .0625" Cutting Length: .250" Shank Diameter: .125"                                               https://www.sparkfun.com/products/15040 10‐24‐18
TOL-15040 价格&库存
很抱歉,暂时无法提供与“TOL-15040”相匹配的价格&库存,您可以联系我们找货
