TOL-15041
TOL-15041
    SPARKFUNELECTRONICS
    DOWNCUT FLAT CUTTER 2PK
TOL-15041 数据手册
    Downcut Flat Cutter - 0.25in Diameter, #251 (2 Pack) TOL-15041  DESCRIPTION This flat mill is perfect for roughing or machining flat or prismatic parts. If you’ve got a Shapeoko, these are great cutters for the DeWalt trim router These are downward spiral cutters, ideal to cut laminates and wood without tearing out the top side of the material. Note: that these have a .250" cutter so if you’ve got a Nomad, you’ll also need a .25" collet TOL15038. Note: Care must be used to have adequate chip evacuation.  INCLUDES  2x Downcut Flat Cutter - 0.25in. Diameter  FEATURES    Cutting Diameter: .250" Cutting Length: .75" Shank Diameter: .250"                                                 https://www.sparkfun.com/products/15041 10‐24‐18
TOL-15041 价格&库存
很抱歉,暂时无法提供与“TOL-15041”相匹配的价格&库存,您可以联系我们找货
