iFixit Pro Tech Toolkit
TOL- 152 55
Having a broken phone or electronics device stinks, whether it's a screen going out, a cable
becoming unplugged, or even a more severe issue that will cost you more money that your device is
worth. The majority of us have had it happen. For those who'd rather "DIY" it themselves, the iFixit
Pro Tech Toolkit for professionals and amateurs alike who are willing to step up to the plate. What
makes the iFixit line stand out from others is the quality of the tools and having the CORRECT tools.
With included popular (but maybe more importantly, unpopular) driver bits and plastic shims as well
as other helpful tools for when you need to remove parts carefully.
The Pro Tech Toolkit has all the tools you would need for fixing most problems with electronics short
of soldering/desoldering components. The folding bag makes for an ideal, space conscious tool set
you can carry with you regularly. Tools such as spudgers and tweezers make dealing with small
connectors and removing parts like screens much less complicated. The well-thought-out nature of
the kit is apparent in the layout of the kit in it's "rolling" organizer and inclusion of a set of
"consumable" tools designed to break before your device does. The rest of the tool set is incredibly
durable and designed to provide solid grip when using them.
INCLUDES
64 Bit Driver Set
o Flex Extension
o Phillips 000, 00, 0, 1, 2
o Flathead 1mm, 1.5mm, 2mm, 2.5mm, 3mm, 4mm
o Torx T2, T3, T4, T5
o Torx Security TR6, TR7, TR8, TR9, TR10, TR15, TR20, TR25
o Pentalobe P2, P5, P6
o JIS J000, J00, J0, J1
o Hex 0.7mm, 0.9mm, 1.3mm, 1.5mm, 2mm, 2.5mm, 3mm, 3.5mm, 4mm, 4.5mm,
5mm
o Tri-point Y000, Y00, Y0, Y1
o Nut Driver 2.5mm, 3mm, 3.5mm, 4mm, 5mm, 5.5mm
o Square 1, 2
o Gamebit 3.8mm, 4.5mm
o Spanner 6, 8
o Triangle 2mm, 3mm
o SIM Eject Bit
o Oval Drive
o Magnetic Pickup
o iPhone Standoff
o 1/4" to 4mm Driver Adapter
Opening Picks (6)
Anti-Static Wrist Strap
Metal Spudger
Halberd Spudger
Spudger
Jimmy
Reverse Tweezers
Angled Tweezers
Blunt Tweezers
Opening Tool (3)
Suction Handle
FEATURES
Tool Roll Dimensions (Folded): 8.4″ × 7.6″ × 2.8″
Tool Roll Dimensions (Flat): 22″ × 7.6″
Tool Roll Material: Polyester Canvas
Weight: 1.88 lbs
4mm Bit Material: 6150 Steel
Bit Driver Material: Anodized Aluminum
Bit Case Material: Recycled ABS
Bit Case Foam Material: EVA
https://www.sparkfun.com/products/15255/5‐6‐19
