TOL-15571
TOL-15571
    SPARKFUNELECTRONICS
    现场测试 电源质量和能量分析仪
TOL-15571 数据手册
    USB Power Meter (Color TFT LCD)  TOL-15571 This USB Power Meter is a versatile little tool that can provide voltage readings down to 0.01V and current to 0.001A, displayed on the built-in color TFT LCD, while your device is connected through it to a power source. You can also measure the capacity and power of battery packs/power banks as well as temperature and cable impedance! In addition to the main numeric measurement interface, you can also toggle to voltage and current bar graph interfaces (because who doesn't like a good graph?), quick charge identification mode, wire group impedance measurement, and a simple settings screen. And with the recording option, you can easily record your data. Mmmmm data... Features              Input voltage: 4.5-24V Input current: 0-3A Capacity measurement range: 0-99999mAh Energy measurement range: 0-99999mWh Load impedance measurement range: 1.5-9999.9Ω Temperature Measurement Range: -10°C-100°C / 0°F-200°F Voltage measurement resolution: 0.01V Current measurement resolution: 0.001A Voltage measurement accuracy: ±0.2% Current measurement accuracy: ±0.8% Recording range: 0-99 hours 59 minutes 59 seconds PD QC2.0, QC3.0/4.0, MTK         https://www.sparkfun.com/products/15571/9‐24‐19
TOL-15571 价格&库存
很抱歉,暂时无法提供与“TOL-15571”相匹配的价格&库存,您可以联系我们找货
