WRL-14868
WRL-14868
    SPARKFUNELECTRONICS
    915MHZ LORA FIBERGLASS ANTENNA T
WRL-14868 数据手册
        915MHz LoRa Fiberglass Antenna Type N - 6dBi WRL-14868   DESCRIPTION If you need maximum distance for your LoRa project you need this incredibly durable, outdoor antenna with 6dBi gain. This 915MHz antenna is 40cm / 15.75" long and includes hardware for pole mounting. Made of fiberglass and aluminum this antenna is ideal for heavy-duty and high-power LoRa base stations but can be used with LoRa nodes as well. Antenna has a type N male termination. When mounted vertically this shrouded connector helps prevent against water and weather build-up on the threads. Note: This antenna doesn’t ship with a cable. We recommend the N to RP-SMA interface cable to connect the antenna to an RP-SMA connector. If you need to go further to U.FL checkout our RPSMA to U.FL cable.                                                            https://www.sparkfun.com/products/14868 9‐20‐18
WRL-14868 价格&库存
很抱歉,暂时无法提供与“WRL-14868”相匹配的价格&库存,您可以联系我们找货
